internal structure
Discussion in 'Tools of the Trade' started by vwshark07, Aug 4, 2008.
  1. vwshark07
    vwshark07 New Member
    what thinkness or weight do most people use for the internal strucker of ships and vehicles to for the skeleton
  2. Padre
    Padre Guest
    Depending on size, at a minimum 2 mm, with a gluing strip of card along the edge for gluing the hull to (usually red, same color of hull). The ship plans usually give you the thickness needed.
    I have looked at some builds that use an extra frame that is glued onto the actual frame but the thickness of the paper used from the frame edge. Then a inner hull is glued to this and then the outer hull has more support and appears smoother. I have not tried this yet but will soon.
  3. vwshark07
    thanks but is there any way to get my directions in english faster than translating than sentence at a time as my kit is the uss missouri from gpm
  4. vwshark07
    or does anyone know of a good translator that actually works cuz the free one i have wont translate half the words
