Interested in Z-Scale...few questions though.
MinnMonkey
I am interested in starting back into model railroading, however I have very limited space, so Z is very appealing to me.
My biggest question is since I do not have a permenant place for a setup, is it possible to create a layout that is more than just a simple loop on a small table without fasting the tracks to the table? I would like to be able to setup and take apart the setup when ever I need the space, plus it gives me the flexibility to try new things.
My second question is if anyone has any recommendations for a good startup kit. I do not want to invest a whole lot of money into this until I give it a try.
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
Sectional track with roadbed is available in both HO and N, but I am not sure what your options are in Z. Creating and re-creating a layout from tracklaying on up can be very time consuming.
I would suggest that there are a number of ways to address using a small space besides simply going with a smaller scale:
- A modular layout that can be set-up and taken down/stored when not in use.
- The narrow gauges - the "rule-of-thumb" is that narrow gauge in one scale will fit in the space of the next smallest scale - e.g. HOn30 fits in space of N, or Nn30 fits in space of Z.
- A different focus - rather than a loop/continuous run layout, you can try a switching puzzle, or a point-to-point, or an industrial switching layout.
- A mini- or micro-layout. This type may be as small as a pizza box, or a briefcase. There are concessions to "prototypical-ness" like really tight curves or implausible scenes, but they can be fun too.
Hope this helps with your layout. And welome to The Gauge! :)
Andrew
MinnMonkey
Thanks for the response!
After doing some more research, I have decided to go with N-Scale (much more affordable). I went to a local hobby shop and looked around, and decided on puchasing the Kato K1 starter pack. I also bought an inexpensive locamotive.
Everything works great, but an oval can be kind of boring. So I am thinking of buying some more track. I am reading alot about the minimum radius I can use..any pointers (I am not too concerned about asthetics at this point, so an over hang doesn't really bother me)? My workspace is current 25"x6' and I would like to use Katos 9 3/4" radius if possible until I get more space.
