inferno tr-15 help
Discussion in 'RC Offroad Forum' started by skidilydidily1, Jul 5, 2004.
Thread Status:
  1. ok i need help i can get the car started with its wheels off the ground, put it on the ground an it stops, it wasent doing this yesterday it was all good yesterday but today it is being a C@!t.i also need to find out how to tune the engine in this beast, any1 help ? matt :) plus i cant get it to idle without the wheels moving
    HELP lol
  2. lostdogeater
    lostdogeater New Member
    lol id help if i could... :D
  3. jackal575
    jackal575 Member
    take off the clutch bell and check your clutch. it is most likely burnt out. do the wheels move when you pull the pullstart?
    to tune your car, follow this procedure: turn the throttle stop screw CCW 2 or three turns and then adjust the trim in your transmitter. once you get the idle right, you have to turn the throttle stop screw CW couple of turns while your throttle is wide open. then let go of the throttle and bring it back to idle setting and turn the throttle stop screw CCW until the drum stops moving. now check that when you brake, there is no movment of the drum. or of course, you can get it done at your lhs
    hope this helps cuz it took so long to write lol
Thread Status:
