Increasing size of model printout
Discussion in 'Tips & FAQs' started by Namrepus221, Dec 5, 2010.
  1. Namrepus221
    Namrepus221 New Member
    I'm wondering if it's possile to increase the size of a papercraft model by printing it out on multiple sheets of paper.
    I have a few models that I would like to give a "Super sized" treatment to. But I dont' know how to do them. I would take them to Staples and have them print out the PDF's on larger paper, but since they are scans from a book from japan, they wont' do it on copyright grounds
    Is there a way to print out a picture or a PDF so instead of it being 1 piece of paper it's spread out over 4 pieces to make one big sheet?
    (Excuse the horrible ASCII) Like this example:
    [X] <- regular size
    [/][\] <- What I want to do.
  2. Wojtee
    Wojtee Member
    If I get that ASCII correct, try the Rasterbator, available here:
    (the original page is out for the moment)
    It does exactly that - splitting images into multiple sheets. Aiming for a certain scale might be a problem, though... But with sufficient trial & error you can get there, I think...
    There are some CAD programs out there (I am positive about ArchiCAD, with which I am working), which can rescale PDF and set which part to print...
  3. Epsilon 9
    Epsilon 9 New Member
    A plotter printer would also do the trick, but I doubt you have one of those handy...
    You could also take the parts in and break them up, perhaps use the percent scale and you'd have upscaled parts. Of course this isn't as easy as the above suggestion, but it would work.
  4. PaperAir
    PaperAir Active Member
    Your printer should have a poster setting that prints one sheet in to many sheets up to 4x4.
