incline question
Discussion in 'G / O / S Scale Model Trains' started by ozzy, Oct 26, 2006.
  1. ozzy
    ozzy Active Member
    ok, im useing lionel fast track, im thinking about putting in a bridge, how much room do i need for the incline? useing the incline kit for fast track. and can i use it on curves?
  2. ozzy
    ozzy Active Member
    knowone has any idea?
  3. JeepMan
    JeepMan New Member
    I don't know the incline grade percent, but a good hobby store would know the answer off the top of there head. Factory made grades or trusle sets would work ok. Installing grades are better on straight sections but will work ok on curves. The rubber traction tires will grip better on straight, then curve. Also keep the rails clean from greese and oil. Install new rubber tires, if needed.
  4. ozzy
    ozzy Active Member
    the only hobby shop with in 140 miles from here that sells trains DO NOT sell lionel tho.
