im new and need help please ?
Discussion in 'RC General & Getting Started' started by caprimanuk, Jun 5, 2004.
Thread Status:
  1. caprimanuk
    caprimanuk New Member
    Just built a new off roader , transfered all radio gear from my old car to the new , and now the steering servo wont work . Ive tried it on another channel on the reciever and noticed that it still doesnt work on that . The other working servo works fine on either channel 1 or 2 off the reciever . So what I did was take the faulty servo appart took off the gears inside then replugged it in and the one cog spins constantly !! have i got a faulty servo ? Will any servo type fit any reciever ?
  2. atc1100rider
    atc1100rider Member
    the servo is blown if just spins
  3. caprimanuk
    yes it spins constantly ! what caused that is it common problem ? will any servo be ok as a replacement ?
  4. bandit1
    bandit1 Member
    well, the cause is wierd to find out with out seeing it, but age is usually the common denominater with servo's that iv had. As far as replacements, basically all servo's will work, u may have to change the elads on them, but thats not hard. the only thing i would keep in mind are the demensions of the servo.
  5. caprimanuk
    thanks for the help , its an acoms servo .
  6. monsterrcbuilder04
    when you order a new one look for one witht he same demensions as the old one.they ussually have the demensions on the box or if you are ordering it they will usually tell you
  7. redheat
    redheat Member
    Try getting one that has metal gears it'll last longer. cost is more but well worth it.
  8. dj6666969
    dj6666969 Active Member
    hey did you check the servo gears????? My servo stoped working all together so I put new gears in it and it worked fine!
  9. redheat
    redheat Member
    Were they metal gears?
Thread Status:
