im doin 180's ...not good
Discussion in 'RC Drifting and Setup' started by newguy2002, Jun 18, 2004.
  1. newguy2002
    newguy2002 Guest
    i have a micro rs4 and i removed the therefore should i just put electric tape on the rear tires....or should i put tape on all four....
    which is better for drifting my setup or AWD with tape...
  2. Rocket-Russ
    Rocket-Russ Guest
    Put your belt back on cos believe it or not awd is easier to control drift and as you said put tape on the front tires aswell although homemade PVC/ABS tires work best but seeing as your using a micro i dont know if you can get the right size pipe for the tires. That should cure the 180 what i believe is happening is you only have RWD because you removed the belt the tape is too slippy for your car to correct with just the rear wheels.
  3. SpArKeY_STi
    SpArKeY_STi Guest
    It is IMPOSIBLE to run a MRS4 in RWD to drift. Unless you try useing just rubber tires, use tape. you can use PVC but your eather going to have to hack the body and car, or just not run one.
