I'm back!
Discussion in 'N / Z Scale Model Trains' started by SD90, Sep 26, 2006.
  1. SD90
    SD90 Active Member
    Hello everyone, it's been a while since I've posted. I have checked in once and a while, but been very busy with moving and getting the new place all finished. Now that that's all done, it's time to start planning the new layout! I've started building the benchwork for the main yard/staging yard. It will be 46' long x 2' wide.
    The new layout will be a single level point to point with a working staging yard at each end. I'm not sure on the length of run yet, it should be between 140'- 200', with 3 passing sidings along the way. The main yard will have 9 arrival tracks and 7 depature tracks, with a mainline run through at the back which will be connected to a 6 track staging yard. There will also be a diesel facility and some industrial areas in the main yard.
    If I learned anything from the Laggan Sub, it is to make this layout somewhat moveable! I'm building it on 24" x 8' and 16" x 8' modules. I will also install drywall for the backdrop, and do it BEFORE installing any track!
    I'll be sure to keep everyone posted along the way, maybe I'll even start a new thread!
  2. SeriousSam
    SeriousSam Member
    welcome back
  3. TruckLover
    Welcome Back Mike
    Boy, this new layout sounds pretty awsome!!! :thumb: :D
  4. storm
    storm Member
    cant wate to see some new pics
  5. 2-8-2
    2-8-2 Member
    Welcome back, Mike!
    Can't wait to see how things develop.
  6. shaygetz
    shaygetz Active Member
    Good to see you back, Mike:wave:
    Nice to see you back Mike, what in the world did you do with your last layout?:wave:
  8. Herc Driver
    Herc Driver Active Member
    Welcome back...As I remember you did some really great scenery. Looking forward to seeing this layout come to life.
  9. Iron Goat
    Iron Goat Member
    Welcome back, Mike... its great to have you back on the forum.
  10. n2trains
    n2trains Member
    Awwww, Mike, I was looking forward to more pictures of the "old" layout. I have kept track of it for roughly 2 years and was THOROUGHLY impressed. I cannot wait to see the pictures of a new layout. Welcome back, and I'm a new member (though I've passively trolled since 04ish). Thank you for your awesome dedication to the hobby!
  11. SD90
    SD90 Active Member
    I got most of the basement drywalled last night, this time, I'm doing that 1st! Since I'm only doing a single level layout, the wall will be the back drop. After it's all done, I'll paint the walls sky blue, and paint scenery on that.
  12. interurban
    interurban Active Member
    Great to see you back Mike.
    Glad the move is over, and the fun is starting:wave:
  13. COX 47
    COX 47 Member
    Can't wait to see some photos....Cox 47
  14. Will_annand
    Will_annand Active Member
    Welcome back Mike, can't wait to see the empire take shape again.
  15. SD90
    SD90 Active Member
    Well almost 10 years, far too long to be away from the hobby!
  16. zathros
    zathros -----SENIOR---- Administrator
    Yeah, it has been a while, glad you've returned. :)
  17. SD90
    SD90 Active Member
    Yes, but I'm starting over, from scratch. Changing railroad modelled, area modelled, control system and SCALE...
    As of right now, I don't have a thing model train related, not a locomotive, freight car, piece of track or switch!
    It's kina, exciting and sad at the same time!
