idle screw problems
Discussion in 'RC Onroad Forum' started by darkendlight88, Jul 10, 2004.
Thread Status:
  1. i own a sirio .12 outlaw engine. im having trouble finding the idle screw. i hav the slide carb. i found the high end and low end. the screw on the back i believe is the mid range. were is the idle screw.
  2. The idle screw is a screw that comes out of the carb at an angle. It has a little spring on it.
  3. i no wat an idle screw is, this isnt my first car but im just sayin i there is no screw on my carb like that
  4. redheat
    redheat Member
    Start looking for a hole then , or your just over looking it.
  5. im not looking over it. look at pictures of the engine ull see there is none. there is no hold for it as if it was missing. theres only three screws. the high end the low end and the mid range.
  6. redheat
    redheat Member
    Looked on the Trinity site couldnt really find anything on your engine other than saying that it has a h/s and m/s . That thing has got to have a idle screw didnt you get a instruction sheet or do your home work before you decided to buy it?
  7. i did do my homework, and the instruction booklet doesnt say anything about it
  8. redheat
    redheat Member
    I'm lost then , I just cant imagine that one of those screws doesnt have something to do with the idle, thats like the first adjustment you need to do when tuning a carb. that mid . screw has got to be it. can youstart the rc and try it or look down the throat and adjust that way?
  9. Ya, take off your air filter (with engine not running) and peek down the carb. Try adjusting all the screws and the one that rotates the barrel should be it. Thats the only way I can think of that you can find out which screw controls idle adjustment.
  10. Ya, take off your air filter (with engine not running) and peek down the carb. Try adjusting all the screws and the one that rotates the barrel should be it. Thats the only way I can think of that you can find out which screw controls idle adjustment.
  11. jimmy
    jimmy New Member
    take out the air filter ...that works
    Foul language removed
  12. redheat
    redheat Member
    Your not gonna get positive attention by posting remarks like that and I think that you no that .
  13. redheat
    redheat Member
    88, any luck yet?
  14. yea the midrange did it thanx alot u guys
  15. redheat
    redheat Member
Thread Status:
