Idea to remove the glue
Discussion in 'Tools of the Trade' started by Manuela Olivares, Oct 18, 2009.
  1. Hello to everyone! :inmew:
    Please I need some help from you. In one day I saw a forum of paper models (can't remember where wall1), a topic that talked about an idea to remove the glue from blades and tweezers.
    I think it was a cork stand where you could stab the blade or tweezers and then stayed clean. But I can't find the topic and I need to know about this. Any idea?
  2. ekuth
    ekuth Active Member
    Well, the cork stand sounds interesting; can't say that I've tried it, however.
    I generally just use an old, dull blade to scrape any dried glue off. You can also try soaking in warm water for a few hours, provided you use white glue. :thumb:
  3. bulldogowner
    bulldogowner Destroyer of Spam Moderator
    I've never tried the cork stand either, but I can recommend a product called un-du adhesive remover...sometimes called goo-be-gone. It removes sticky residue and glue from just about anything...just be careful and use in a well ventilated area...otherwise lights give off a very interesting glow.....
  4. Retired_for_now
    Retired_for_now New Guy
    I just scrape glue off of tweezers with a chisel edged tool or let if flake off of blades when I run them through a carbide sharpener or steel honing wheels.
  5. Elliott
    Elliott Senior Member
    Take a look at this link here.
  6. Elliott
    Look at the 2nd picture from the bottom. Is this what you were talking about Manuela?
  7. Jef
    Jef New Member
    For cleaning i use alcohol or benzine for lighter :thumb:
  8. Claus
    Claus New Member
    Aceton or nail polish remover. Both work fine and even remove cyanoacrylate (super glue) and acrylic paint.
  9. voltron5
    voltron5 Member
    Same as Ekuth I generally used to use my cutting blade to scrape glue off tweezers and other tools before I change the blade. When I build anymore though I keep a small glass of hot water next to me and a papertowel to clean off every tool after use, such as knives if I get anything on them or a fine tip paintbrush which I use to apply glue with or edge coloring. The cork thing sounds like a good idea although it would have to be fairly large to prevent it from tipping if you plan on storing knives and such in it.
    Welcome to the forums:thumb:
  10. el Leon
    el Leon New Member
    Pitchwood is used for cleaning twezers, tools, shafts & pins etc.
    Is a wood soft than the cork.
    pd: Pitwood stand for cleaning blades and other tools
