I need more BITE!!! RC Tuning question....
Discussion in 'RC Offroad Forum' started by bandit1, Aug 21, 2004.
Thread Status:
  1. bandit1
    bandit1 Member
    I just got back from my track, and I'm very staisfied with how my B4 is going into and thru the middle of the turn, but its lacking grip coming out of it. What would u guys suggest i adjust on it to get more bite out of the turn. By the way, it a short oval track, thats pretty flat. thanks..
  2. tnx
    tnx Member
    front wheel drive, better gripping tires(depends on how flat)put more weight in the front of the car so the front wheels have more grip and then it wont drift(thats because the back wheels grip most)
    these are all i can think of so far
    Tim
  3. bandit1
    bandit1 Member
    thats a good idea thanks. the B4 is a very light car, so i didnt think of the wieght transfer aspect. ill try doing that and see if it helps, thanks dude.
  4. monsterrcbuilder04
    if you pick up a rcca mag and looka t pros cars you will see that they add little wieghts in some of the corners
  5. tnx
    tnx Member
    no prob man, like to help ppl with problems :)
  6. redheat
    redheat Member
    I've got a B4 and there not that light, try some Losi pin tires for traction and of course rib up front, what are you running for gearing and ESC, Motor, Cells , RED
  7. bandit1
    bandit1 Member
    20 tooth pinion, dunno bout the spur(watever came with the kit),esc-streak(thats stuck in forward, if any1 knows how to get it out, or reprogram it please help!!) and motor-13turn, 7 cell battery with 8.4 volts.
  8. redheat
    redheat Member
    That streak is crap I had the same problem with one that I got of of Ebay, I could not get the thing to g oto brake no matter what I did so I got rid of it, and replaced it with a Novak GT7, Tons of fun, RED
Thread Status:
