I got a RS1 at last
Discussion in 'HO Scale Model Trains' started by interurban, Jun 25, 2004.
  1. interurban
    interurban Active Member
    I folks , I have been messing around with the idea of running live overhead + two rail for my old diesel`s.
    Because I now have end to end running I will be able to run both :eek:
    All I have to do ,,,,is do it :D :D
  2. Clerk
    Clerk Active Member
    That's great Chris. For a while there I didn't think you had any diesels, just overheads. :thumb: :thumb: :thumb:
  3. jim currie
    jim currie Active Member
    i some where have seen a photo of a diesel on the Pacific Electric ( i think its the one :confused: ) running with a trolley pole not to power diesel but for signal detection . as a model you could power it off trolley wire :)
  4. mykroft
    mykroft Member
    I've seen a couple of shots of S-1's and S-2's with a Pantograph.
    Often it's simply required to activate signalling, although they may be able to power the traction motors as well, if it's a 600V wire.
  5. interurban
    I could pan them ;) But,,,no,,, I will have them slowley wandering around with my frieght "orders" :D
    It will add to the lay out op`s and give more photo ops too :thumb:
    I hope this weekend I can have the wiring sorted!! a couple of center off switches should do the trick.
    I will have the fire dept standing by :thumb: :wave: :D
  6. CN1
    CN1 Active Member
    More pics Chris. pleaaaaaaaaaaaaaaaase!!! :( :eek: :thumb: :thumb: :D
