i got a rover mini 1/10 front.w.d how to make it drift plz
Discussion in 'RC Drifting and Setup' started by rover_mini, Mar 19, 2005.
  1. rover_mini
    rover_mini Guest
    I got a rover mini cooper 1/10 i got speed gem motor
    and my tires ar so worn out that i want to know how to make
    it drift. if its possible. :?
  2. SpArKeY_STi
    SpArKeY_STi Guest
    Herm, earler you said it was FWD. Lucky. Anyway, this presents a challenge. Your best bet would be to use PVC wheels, and electral taped fronts. Try that and tell me results.
    Also, have you ever drifed a PVC Rc car?
  3. rover_mini
    rover_mini Guest
    NO I HAVENT RACED WITHE PVC I DONT KNOW WHER TO PUT THEM IN THE FRONT OR IN THE BACK I GOT ELECTRIC TAPE TO DO YOU THINK
    ITS POSIBLL TO DRIFT A MINI COOPER :idea:
  4. SpArKeY_STi
    SpArKeY_STi Guest
    Calm down...
    Read my post again, it says what i believe you should do. I was just asking if you have used a AWD car with PVC before, wondering if you knew how it works while driving with PVC. then, you would have an easier time useing a FWD.
  5. 69stang
    69stang Guest
    wow u realy need to chil out dam wer just heir to help
  6. rover_mini*
    rover_mini* Guest
    soory that i havent replyed becuas my parents diconnected my internet
    so i tried to use electric tape and ot barly works know what i did :idea:
    i got my mini cooper and i was mad and tuck it all apart and bam
    i maid it back well drive that was cool but i dont like it that much.so i herd
    that i chuld use polypipes will that work
  7. rover_mini*
    rover_mini* Guest
    ooooo umm i forgot my password and maid a different one
  8. iGuy
    iGuy Guest
    Not to be making you pissed or nething,...
    But i was tryin that its like impossible for me to drift a FWD.
    I took the rear belt of the HPI Pro 3.
    All i can do is wip my tail out but the car does not slideand if i do slide its a 180. not a slide.
    But maybe if the mini cooper is shorter and the weight is different i might be able to drift it with tape or pipes.
    Tell me the result too i wanna know.
  9. SpArKeY_STi
    SpArKeY_STi Guest
    really the best thing to do would be use PVC, and find a way to lock up your rear end, without disturbing the front. That way your rear is gripless and has no choice but to go where the front wheels make it. So, use PVC and lock the rear for braking. Not sure how thats going to work, but its possible.
    And instead of trying to do all this, drop all this money to try and do this, just go and buy a AWD kit. Hypotheticly, your not going to get it to work. You have to be able to think like a circle, and know a lot about drifting, physics, and the RC Car workings.
  10. rover_mini*
    rover_mini* Guest
    ok but how much ar thay :?:
  11. SpArKeY_STi
    SpArKeY_STi Guest
    Depending on the kit you choose, if you get a RTR or a Kit, it will range from around $100USD to $400USD depending on brand, chassis, and what you currently own.
  12. rover_mini*
    rover_mini* Guest
    what is all that jumbo in american $$$$.
  13. SpArKeY_STi
    SpArKeY_STi Guest
    USD is United States Dollar. So read it again and its exactly as it says...
  14. rover_mini*
    rover_mini* Guest
    thats to much 100$$$ dollers :shock:
  15. SpArKeY_STi
    SpArKeY_STi Guest
    Good luck with anything then. Cause $100 doesnt really get you far, at all. A TC3 is $300, Kit its $250 + ~$150 for ESC and Tx and Rx, Plus Your motor and such. So your just going to have to find your own way to make it work.
  16. iGuy
    iGuy Guest
    you just busted that poor guys Bubble LOL.
    I still see no traffic whatsoever.
