HPI RS4 MT-1
Discussion in 'RC Offroad Forum' started by Skandranon, May 27, 2004.
Thread Status:
  1. Skandranon
    Skandranon Member
    Does anyone have a hpi rs4 mt, the first version? I am intrested to hear anything anyone knows about this truck.
  2. Skandranon
    Skandranon Member
    Nitro, 4wd version not the eletric
  3. dj6666969
    dj6666969 Active Member
    umm I know its shaft drivfing with a .15 engine. I have looked on HPI's site and the only really difference is the motor
    HERE IS WHAT SEEMS TO BE THE NEW THINGS ON THE TRUCK AND I GUESS EVERYTHING ELESE IS THE SAME?
    T-15 engine with ABC construction and 2 needle carb
    redesigned suspension for more wheel travel
    HPI Roto Start System installed
    aluminum tube header
    composite dual chamber tuned pipe
    stronger plastics for extra durability
    scale Yokohama Geolandar M/T tirespreglued on chrome plated wheels
    fiberglass disk brake for great stopping power
    longer redesigned assembled oil-filled coil over shocks with purple anodized aluminum shock caps
    18 purple rubber-sealed ball bearings
    larger ball cups and dogbones for increased durability
    sealed gear differentialswith stronger metal diff gears
    adjustable body posts front and rear
    spur gear protector
  4. pimp
    pimp Active Member
    can u all send a link of a pic i have never heared of 1 can u find them on ebay?
  5. Skandranon
    Skandranon Member
    Wow, thats a big list. To just do everything on that list would cost a bit. :p
    Pimp
    Here is a link to hpi website:
    http://www.hpiracing.com/index2.htm
    From there click on kits mt2, that is the new vesrion.
    For pictures of the 1st one (the one I have):
    http://www.nitroreview.com/TheDatabase/homekits.cfm
    scroll down to truck (below stadium trucks)and click on HPU Nitro RS4 RTR.
    There are alot of the MT2 on ebay. Also some used MT1.
  6. Skandranon
    Skandranon Member
    Does anyone know if they make a roll cage for the nmt? I have looked and cant find one anywhere. Is there one for something else maybe that could be made to fit?
  7. dj6666969
    hmm I dont think you need 1 tha goes around the hole chassis maybe just around the engine so if it does tip it wont get messed up
  8. niner
    niner Member
    no roll cage on these cuz they r not needed it already has a partial on it to pretect
  9. mr_chris04
    mr_chris04 Member
    how about a mt-2 does any one know about that reply to my post
Thread Status:
