Biased turkey
I did some googling , found plenty of links about assembling and installing MTL couplers, but none about how to replace a truck with an MTL truck assembly .
Is it done by just removing the plastic pin holding the original truck in place, removing the original truck, installing the MTL truck and inserting the plastic pin back ?
Any hole to drill or tap ? any shim to install ?
tia for any info.
tia for any info.
