How to?
Discussion in 'HO Scale Model Trains' started by UPJunkie, Aug 27, 2003.
  1. UPJunkie
    UPJunkie Member
    How would i go by making a top layer to my layout? I never tryed this before so i would not know where to start:confused: :confused:
  2. billk
    billk Active Member
    What do you mean by top layer? Covering your present layout surface with scenery? Adding a second level to your layout? Modelling a blue-ribbon hen in a farm scene?
  3. UPJunkie
    UPJunkie Member
    Here is a pic of what i want to do.
    I hope Ray Marinaccio dont mind me using one of his pics to show what i want to do. If you do mind i will find a diffrent pic
  4. Ray Marinaccio
    Ray Marinaccio Active Member
    Don't mind at all. If one of my photos can help you get an answer to a question, thats great.
    As for the top layer I used a few diferent methods on this layout. The 2" foam subroad bed is held up by supports from the benchwork on the first part of the grade (front center) and the topof the hill (far right). The second section of the grade ( where your arrow is) is supported by foam supports cut to size then the foam was cut and stacked around it. and the upper return loop is resting on layers of foam stacked on the benchwork.
    It doesn't need to be that complicated. you can add layers of foam to your existing layout and get those flexable foam grades.(made by Woodland Scenics I think)
