how to slow down an electric pulley ?
fran1942
41
Hello, I am a real newbie when it comes to electrical mechanics etc, so I be really happy for some help.
I have a Tamiya electric pulley unit set up to form an aerial tramway.
The trouble is that when I connect a battery to the electric motor, it runs too fast. The RPM of the motor is too much for a realistic tramway.
I am using the smallest battery that will power the motor. It is a 1.5volt battery.
I know gearing would normally be the answer, but there is not room for additional gears on the Tamiya kit and it is all custom built. I have my small pulley wheels driving the large pulley wheel, but the speed is just too fast.
Can I buy some sort of power regulator to slow down the electric motor ?
If I bought a smaller electric motor would that have lower RPM ?
Any ideas would be most welcome.
Thank you.
liven_letdie
164
Turlock, CA
www.downthelinetrains.com
You can do a couple of things, however i am no expert so do your homework first. You can get a potentiometer (pot) which would be a current control/speed control (imagine a volume knob on a stereo). Or you could make a small circuit board with resistors to give one speed. Im sure others will have better ideas, but its a place to start!
Cory
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
Boy, you're getting way down there on voltage at 1.5 volts, but if that's too much, you might get by with adding a resistor in series with the supply voltage. What size? That's going to depend on how much current the motor takes running a full speed. If you have any resistors available, you might try a small value first, like maybe 50 ohms, and go up in value until you get the right speed. What that does is lower the voltage to the motor and it should lower the speed.
If you had any specs on the motor, then we could be more precise in the resistor value range. See if there isn't any voltage and current data stamped on the motor or instruction sheet.
fran1942
41
thanks very much for that. It seems a ceramic resistor will do the trick.
Excellent advice. I am off to electrical wholesalers right now to pick one up.
Thanks guys.
pgandw
1,002
In lieu of specs on the motor, you will have to do some experimentation. You need to determine what is the lowest voltage the motor will run at satisfactorially, and what voltage gives your tram the speed you want. Use a variable DC source ( a good power pack) and voltmeter for these tests. Hopefully, the motor will run properly at a slow enough speed to meet your requirements.
What type of battery did you use? D, C, AA, AAA (all are 1.5V)? If you used one of the smaller batteries, and the motor still went too fast and didn't drain the battery immediately, then that is an indication the motor is probably a high efficiency, low current motor. It will take a higher value resistor than some other motors - probably somewhere around 7-10 ohms. The good thing about a low current motor is that the resistor rating only needs to be 1/4 watt.
If the motor will not run reliably at less than 1 volt, you are going to have to increase the mechanical reduction - either gear or pulley - or find a lower RPM motor. Typically, the smaller the motor, the higher the RPM - but there are other factors here too. Using a motor rated at 3 volts instead of 1.5, even though having the same top RPM, might give more control.
Hope this helps.
johnny b
112
Is there anyway to change the pulley size itself to something bigger. Or modify it ? A bigger pulley or wheel would make the overall operating speed slower. The bigger the wheel or pulley the slower it will go. No matter what the voltage and speed of the motor. Just an idea though.
jim currie
1,383
arizona
as i remember it goes like this the RPM of the motor times the diameter of the driver divided by the diameter of the driven 100rpm *10 inchres = 1000/20 =50 rpm.
