How many times????
Discussion in 'Scratchin' & Bashin'' started by twilight, Jan 22, 2004.
  1. twilight
    twilight Member
    Have you ever scratch-built something and you really felt you were on your way to having it completed and than suddenly you realized you over looked something? Well it's been happening to me! I've been working on a wooden trestle with embunkments(?) in to the scenary and after having the darn thing nearly completed, I realized my rolling stock won't clear the corner of a wall I had constructed!:mad: Please, lend me your support!!!
    Has this ever happened to any of you guys??? I'm realitively new to this, so guess I must persevere!!!
  2. shaygetz
    shaygetz Active Member
    As a Senior Member, I plead the 5th:p
  3. Russ Bellinis
    Russ Bellinis Active Member
    I think only armchair modelers have never had something like that happen.
  4. Lightbender
    Lightbender Member
    Hello Twilight,
    I really hope you don't expect me to admit in public that I recently had to take a pair of side cutters to my permanently installed station awning for that very same reason.
    That would suggest that my 50+ years of modelling has taught me naught.
  5. Matthyro
    Matthyro Will always be re-membered
    I believe it is a learning process. We try something and it either works or it doesn't . If it works, great. If it doesn't we have learned something which will stand us in good stead the next time we try something else.
    If we don't try without a risk of something going awry then progress deminishes. My mother always said to me "Try, try again. If it doesn't work the first time , do it over". I can't tell you how many times I have torn apart what took hours to put together. The only crime would be not to do it again.
  6. Arlaghan
    Arlaghan Member
    It happened to me. I was scratch-building a timber deck truss bridge and there wasnt enough clearance underneath it. I had to scrap it and make a regular truss bridge instead. Fortunately, I only made a little bit of progress and went to check on that.
  7. shaygetz
    ...I still plead the 5th.:rolleyes:
  8. George D
    George D Member
    Robin, if it’s was a “learning process” then I’d be a genius by now. :) Unfortunately I still make my fair share of mistakes.
  9. grumbeast
    grumbeast Member
    Yeah, me too..
    After scratchbuilding a wooden station platform in
    N with scale lumber (in situ.. my first mistake!) I discovered
    that while my diesel locomotives ran past beautifully
    all of my steam locomotives running gear hit the edge
    and derail. so a LOT of time with some sandpaper fixed
  10. Mike R
    Mike R Member
    Having done some foolish things myself, I recall I didn't PLEAD the fifth, but did DRINK one after a couple of the more distressing occasions.:cry:
  11. jon-monon
    jon-monon Active Member
    Where I usually get into trouble is reassembling something I took apart. The pickup wipers on N scale locos in particular tend to be out of place after assembly, requiring I tear it all down and start over. In fact last night, I was working on an 0-6-0, cleaning/oiling/fixing/improving, and 2 or 3 times I put the drivers back in with the pickups out of place (slow learner!). :curse: :curse: :curse:
    Well, ya just gotta take a deep breath and start over when that happens, weather it's a half hour lost or a week. :(
  12. Fred_M
    Fred_M Guest
    Spent hours putting in wood pilings between the creek and the track. Even checked it for clearance using a F-7 and a 86 foot flat car. Got it all painted and weathered. Went highballing around it with a GP7 and the front steps hit it derailing the GP and dropping several cars all the way to the floor. Spent more hours reworking it to clear the GP7. DASH
  13. Ralph
    Ralph's for fun!
    Been there! I made a tunnel entrance and made certain it was OK on clearances but I neglected to test a last minute addition retaining wall to the side that caught locomotives as they rounded the curve into the tunnel. You are not alone! :)
  14. twilight
    twilight Member
    Thanks everyone for your replies!:) Didn't have the heart to correct the wall last night, but it's on my list of things to do, tonight!!!
    It's funny I tested my little saddle tanker(all I'm running on this layout) by the wall and it was fine!!! So I was all excited on how well it was working and looked! But then I add the the box car!:eek: :eek: :eek: ....:curse: :curse: :curse: And it was back to the drawing board!!!
    Thanks again everyone!!!!:)
  15. shamus
    shamus Registered Member
    Well I once took a loco apart to clean it, put it all back together and it ran perfect. -- Then I noticed I had some tiny nuts and bolts left over. I still have them LOL
  16. rebel
    rebel New Member
    you old pros ever hear of a clearance car
  17. Fred_M
    Fred_M Guest
    Them cost money that can also be used for super detail parts, scenery, rolling stock,... Some people buy tools, some people use borrowed tools.:D :D :D DASH
  18. Ralph
    Ralph's for fun!
    a what-now...? :D
  19. shaygetz
    Got one o' those, 90 scale feet long, 20 scale feet high and 16 scale feet wide and the club auto-racks still manage to find things to hang up on:curse: :cry: :oops: :eek: :rolleyes: 'Tis the thrill o' comin' out right just once that keeps me building.`
    I'm pretty good in the scenery/building dept, can't recall anything of real note. All my stuff happens under the hood, like the time I inadvertently wired a decoder in around the drive shaft---twice---on the same loco. Or when I hooked up 4 of those beautiful bright white 2mm LEDs at $6 a pop to a new decoder and remembering they're rated at 1 1/2 volts---after---power was applied.:oops:
