How do you remove and install Athearn flywheels?
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
regular superglue may not be the best choice. It doesn't hold up well to torque. A-Line / Proto Power West sells special glue for flywheels that is cheap, and works. I used it when repowering my E60 dummies, and so far they have not broken yet.
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
you don't need a wheel puller to remove flywheels. Simply twist the fly wheels in opposite directions simultaneously. this will break the bond that the flywheel is glued with on the shaft. they should simply slide off with little effort.
