Hi Ralph.
One of my treasured memories is, as a twelve year old, being allowed to sit in the cab of an older (AC-4) S.P. cab-forward. I observed the practice of the "art" of train teamwork by the man at the throttle. We were hooked onto the rear of a ninety car freight, with nothing behind us but the caboose. We were on a siding just at the start of a better than two percent grade about ten miles in length, waiting for the eastbound Daylight to clear.
As soon as the passenger train cleared, the switch was thrown at the head end. Watching the brake pressure, and receiving a signal from a brakeman standing atop a freight car, the engineer knew when to start pushing. He explained as we started that the head end locomotive was not doing anything and we would apply all the power until it was obvious more power was needed.
At that point, the head end would start pulling. Both the pushing and pulling loco operators knew from experience when to add power or slack off. The goal was to get the consist safely and gently over the grade without stalling or breaking a coupler. At an average speed of around 10 mph, (as slow as a slow walk and as fast as perhaps 15 mph) it took just under an hour to "make the grade". It wasn’t as simple as it sounds, as there were some areas where the grade was less and others where it was more. It was also essential for both engineers to monitor the brake pressure and remain alert for signals from the crew as something could always occur which would require an emergency stop.
At the summit, still moving, we were unhooked from the train and slowed until it was about a hundred yards ahead of us and the siding was clear. At that point, we poured on the steam until we were moving faster than the train. The caboose was unhooked behind us, we pulled into the siding and a brakeman threw the switch so the caboose could catch the train. This latter operation was probably the most impressive part of the whole show.
Almost as vivid in my memory is laying abed at night and listening to the trains. Their exhaust would slow as they hooked into the grade until it was often a second or more between chuffs. These articulated engines gave a “double chuff” on each stroke because of their double cylinders. The sound was “chuff (hesitate) chuff (pause) and then chuff (hesitate) chuff (pause) again.
Forgive me if I got carried away, but the subject takes me back to some of the memories that always kept me hooked on railroading.
