how do i ...............
Jun 18, 2004
487
barboursville, wv
hey everyone, i have a freshly painted Kato SD45 that i need to strip. the thing is, it has had extensive customization done to it. i used CA to assemble the new cab and sub base. the paint i used is Poly Scale water based paint. will 91% alchaol safely strip the paint with out affecting the parts glued with CA? any information is greatly appreciated. thanks!:wave:
Matthyro
Will always be re-membered
Dec 28, 2000
4,550
Georgetown, Ontario,Canada
Steve, I have used Poly S easy lift off, paint and decal remover. It says it works on most types of paint. Doesn't say anything about CA so if you get some test it on a scrap piece first tp see what happens.
