HO windows for scratchbuilding
Discussion in 'Scratchin' & Bashin'' started by galt904, Jan 20, 2005.
  1. galt904
    galt904 Member
    I am planning to build an HO scale model of my house to place on my (still in the planning stages) layout. I am planning to build the house using wood board & batten siding. If I take a Pikestuff window from one of their kits and turn it sideways, than the height is right, but the window would be way too wide. Would it be fairly easy to modify these windows to get the right width, or will that end up too messy? I suppose I can always practice on one to see if it will work or not.
    To get to my real question, what different companies sell windows for scratchbuilding?
  2. Fred_M
    Fred_M Guest
    I like Grandt Line windows. Fred
  3. galt904
    galt904 Member
    Does Grandt Line have an online catalogue at all?
    Edit: OK, I found their website. The closest window to what I need is the #5032, except I don't need all the panes, just the double hung frame. Are the panes easy to remove, or are they too fragile?
  4. George D
    George D Member
  5. Fred_M
    Fred_M Guest
    No, they can be taken out with flush cut nippers. Fred
  6. CalFlash
    CalFlash Member
    Save those mullions you take out in modifying the windows! I just got done using some I scavanged from a Grandt Line window to add to a lazer kit's windows and door to change the appearence. Takes careful cutting but doeable.
  7. galt904
    galt904 Member
    Great! Thanks guys. :)
