HO train layout
Discussion in 'HO Scale Model Trains' started by freddog262, Dec 26, 2006.
  1. freddog262
    freddog262 New Member
    well hi, new to the site: got a problem,,have put together a HO train layout and there is about 30 some feet of track..I have a Teck II model 2500 transformer. The problem is that it doesn't seem to have the voltage necessary to run my trains...Wondering what to do...have got multiple wiring sites along different parts of the track..if I hook them all up will that work...Ralph
  2. cidchase
    cidchase Active Member
    Quick answer is Yup.
  3. cidchase
    Welcome to The-Gauge, Ralph!!:wave:
    More feeders will be better. Tracks can exhibit voltage drop
    in wiring and joiners.
  4. freddog262
    hi again, thanks for the information,,,will give it a try and see what happens...again thanks for the reply
  5. 60103
    freddog: if your train runs fast enough near the electrical connection, you have enough voltage. Track joints create resistance and waste electricity. Put more feeds around the layout and there will be less drop off. But use a larger wire going around. And make sure the connections go to the proper rail. Check after you install each pair.
  6. Ralph
    Always good to meet another Ralph! :) Welcome to The Gauge. I hope the advice you've received here helped get that train running!
