Ok, I need a HO track plan for the area 96" x 112" (8' x 9'4") that will be expandable to 96" x 290" (8' x 24'). I would like an open center, once around at least, maybe double deck, broad curves, #6 for main, # 4 for yds and spurs. Most of my locos are SD's, big GE's, and articulated steamers. My roadbed will consist of 3/8" plywood strips covered with 2 layers of 3/4" foam and cork on top of that. My area against the wall be no wider than 6-8" and my inside area will be no larger than 2'.
My work area is this:
and my bench is this:
and my track plan is similiar to this:
the dotted lines on the left and right go up to upper level. I haven't worked on it yet. I'm more concentrated on long running than switching right now. But I will put in a turntable and diesel service facility on the upper level, along with some industries.:thumb:
