HO Track id
huttojb
23
Hi Gents.
A quick questions what the difference between
HO CODE 83 TRACK and HO CODE 100 TRACK?
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
Height is measured in 1000th's of an inch. Code 83 is therefore 0.083" high, and Code 100 is 0.100".
However, the overall height of the track can vary due to differing thickness of ties. For example, my Walthers/Shinohara turnouts and Atlas flextrack are both Code 83, but the ties on the turnouts are thinner, so need to be shimmed so the tops of the rails are even.
Atlas has addressedm a similar problem - their Code 100 and Code 83 track are the same height overall, since they put slightly thicker ties under the Code 83 rail.
Andrew
huttojb
23
My father-in-law is using "OO" I read that the HO is compatable, my father-in-law said the tracks are different????
Is this true, what are the difference?
Jason
MasonJar
Oct 31, 2002
5,362
Ottawa, Canada
"OO" (double-O, or dubblo) is a Bristish scale of 1:76 - above the railhead. However, it uses HO standard gauge track, which scales out to slightly narrow gauge if measured in 1:76.
So the tracks are in fact the same. It is everything else that is slightly larger than HO scale.
Confused yet? ;) :D
Andrew
huttojb
23
so if my father-in-law is using OO, what one do I need to get HO Code 100 or HO Code 83?
Jason
MasonJar
Oct 31, 2002
5,362
Ottawa, Canada
Code 100 is the safest bet, because if the wheels on the OO locos have large flanges (look like pizza cutters ;)), they *might* bottom out on the spikes on the Code 83 track.
Take a loco to the store with you if possible to check it out. Code 83 would look better in my opinion.
As for scale, I have no idea what the point is. Why do trains come in 1:87 in North America, but 1:76 in the UK? And why do airplane models come in 1:72? The most bizzare thing is that OO scale (1:76) is defined as 3.5mm (or is it 4mm) to the foot... mixing two entirely different measurement systems.
And while we are on that, why are US gallons different than UK gallons? I could go on...! ;)
Andrew
LoudMusic
620
huttojb said:
whats the point in that!!!!!
thanks.
You have seen the light! I've been screaming this for YEARS about various modeling practices.
This being one of the issues I have. I can understand they want it to be easily transitional, but honestly, they've done the exact opposite of "true to scale". The ties on smaller weight rail should be SMALLER! Not bigger. They should manufacture proper height and produce a set of transitional pieces.
huttojb
23
I could be on thin ice here, but obviously the english version is the correct one, just like we drive on the correct side of the road!!!!
Thanks lad's I'll let my father-in-law know.
Jason
LoudMusic
620
Jason
How is incorrect scale track better than correct scale track?
OO is predominant in the UK, but runs on HO track. HO everything is predominant in the US, making buildings / people / trains / and TRACK the same scale.
huttojb
23
We could discuss this all day, but I think it will be better if we call this a day.
Another question, could someone post a picture of a Point and Y track and tell me what bit's are electronically connected. And according to my father-in-law they are different (looks the same to me) could someone explain.
Thanks
Jason.
LoudMusic
620
Thanks
Jason.
Uh huh.
Ok, by "point" and "y track" are you refering to a turnout?
huttojb
23
OK. I've tried to attach a pic but it goes over the file size?
at the bottom of this pic there is an upside down V; is this electronically connected to any input from the top of the PIC.
Is a turnout and Y the same??
Jason
huttojb
23
back onto the correct side of driving??
Can someone answer my question and I'l be happy to discuss the advantages and disadvantages over the UK and that other place over on the west somewhere???sign1
4,501
Lakewood, Ca.
Jason
A "Y" track is a type of turnout. The prototype just call them switches, but we modelers refer to them as turnouts to keep from confusing them with electrical switches for turning power on & off. The turnout in the pic is a right hand turnout because the curved track goes off to the right. A "Y" turnout would not have a straight and a curve, rather it would be 2 curves going off in opposite directions to make a "Y" shape when viewed from the top.
