HO steam loco repair
Discussion in 'HO Scale Model Trains' started by GYurick, May 28, 2002.
  1. GYurick
    GYurick New Member
    I have an HO steam 0-6-0 loco that needs service. Specifically, the rubber tire has stretched and needs replaced. I do not feel confident about doing the work. I would probably do more harm than good. Can anyone recommend a trustworthy source for this?
  2. sumpter250
    Most hobby shops have, or can recommend, repair services.
    Traction tires, and tools for installation are not that expensive. If you can learn how to repair these things, there's less to worry about, and more time for fun. You might consider trying the repair first, and if that fails, at least you have the old tire off, so installing a new one won't take that long.
    Pete
  3. yellowlynn
    yellowlynn Member
    repairs
    GYurick
    I can understand how you feel, been there, done that. I have a 4-8-8-4 Big Boy that blew a tire. I got a pack at the hobby shop. It is necessary to take the drive rods loose from the wheel so the tire will go on. Lay the loco on its side, on a thin piece of foam, or anything to keep it from sliding. Take the screw out, remembering exactly how the rods went. Use Scotch tape or such to keep them together. Slide the new tire past them. Then, either connect them back if you feel squirrely, or put the tire onb the wheel 1st, then reconnect. Always do just one at a time,if possible and there should be no problem. Also, use tape to hold the screw, or you'll lose it for sure. That is experience talking there. Good luck.
    Lynn
