Hi, Barry!
Still following this magical process with great interest and dreams of designing my own model...we can dream, can't we? :lol:
Just a few questions on the last set of steps.
1. In step 10 a it seems you have printed out two sheets, at least, of the plan file image, each covering a part of the original plans, with it idea being to assemble a complete ship plan on paper...is that right? And then I read into the instructions you take that assembled paper mock-up with which you have decided the breaks to fit your chosen paper size and then rescan the parts you have physically re-worked...am I still following your instructions correctly? Just wanted to be sure you were talking about a print, mock-up and join, and then rescan of the newly printed parts to fit your desired assembly mock-up into new files for further use in the process. If I am not right, please show me the error of my ways...see, I told you I am a computer idiot.
2. I also imagine that before you print out the first mock-up sheets you have already decided on the scale you want to build this model at, right? So, the plan set you start out with should be altered to match the scale you want, correct? That way the printed out mock-ups in step 10 are true to your chosen scale, right? So the scan you make is not in the desired scale...or am I going astray an asunder here?
3. You mention in step 11 to "turn off the 'resample' box"...why? What does that do if you don't? Just curious. I also take it you start out step 11 having already reloaded the new scan of the mock-up parts, is that right?
4. In step 13 you mention "frame markers"...what are those? Are those the indications on the plan showing where the frame sections are taken from? As they are usually shown on the profile section do you have to draw a line using the edit tools to the deck plan to have the frame locations indicated there also? Is this what you are doing in step 14?
5. Now, in step 15, are you essentially printing out what you have just made in the prior step, or are you just printing out the main deck view? I surmised at some point you have taken parts of the re-scanned mock-up and copied parts and pasted onto new pages that match the paper size you are working with, is that right? So, when you print out the next batch you are printing out the new pages you have just created...and are you printing out the entire batch so you can piece together another mock-up, this time the parts have the frame locations on them?
6. In step 16 you are creating the frame former parts...do you use the grid function to check to see that the center line on your frame plans are true vertically before making the mirror copy and creating the full frame? I can see an error creeping in if the plan you are working with is not trued up to the center line around which the frame parts are rotated. BTW, did you mean to say horizontally flip or vertically flip the frames. Most frame plans I have seen are centered vertically, one side being one-half views of the frames sections forward of midships and the other being the after frame sections. I'm just thinking if you flip on the horizontal axis (a line that runs across the page from left to right) you are rotating on the wrong axis...or is my computer ineptness again rearing it's ugly head? Maybe I'm just not familiar with the terminology used in the software, which is definitely a given in my case.
I know what you mean, though; you want to use the half frame lines to create a full frame former.
7. In step 18 you say "cut the frames in the size you want"...I'm not sure I understand what you mean by "the size you want". I am presuming the files you are creating are keeping the same scale so they should all be in the correct size, right...or did my brain take another detour somewhere?
And are you are printing out all the frames copies now, taking one full frame from each copy to make up the various different frame formers? Should you label the frame copies at this point and edit to clean up the other frame lines you are not working with for that particular part? Is there a way to label each individual full frame former at this stage so we know which one it is, having now create individual frame formers... or did I just take a different tangent than your instructions call for?
8. In step 19 you say "make half cuts to attach to the spine"...are you referring to cutting the full frames parts in half or do we make slits to join them with similar slits in the spine or profile parts (the center spine which is the vessel's profile view)?
9. So at this point we have the basic hull made up of the base plate, main deck, profile/spine and the various full frame formers, right? Are we dealing with the other decks or levels that make up the main deck right now (if that is how your vessel is designed?)...for instance, the main deck, as you have noted, sometimes has a break for the forecastle...are we printing that part out too, so as to make a full top deck to work with in our mock-up in cardstock? This question also applies if there is any quarterdeck, the aft deck that is raised from the weather or main deck, in some ship designs.
10. What type of errors and adjustments have you seen necessary at this early stage, if any, to the parts files you have described so far? If you don't have a waterline plan, the one you use as a baseplate, do you have any suggestions on how we use the main deck plan to create one based on the lower portion of the frame formers?
So sorry for the multitude of questions, Barry, but I
did say I was a computer idiot, didn't I? :lol: Hey, it's only ten questions...well, okay, some have many parts, but not bad, right? Seriously, I am following your step-by-step very well and, despite appearances, am not completely lost... yet.
I figured I had better ask some stupid questions now before my mental wanderings lead me too far afield...it's not your instructions, Barry, they are great, it's just my trying to visualize things in my own mind and be sure I am not mistaking your descriptions.
Yeah, I was the one in the back of the class always interrupting the teacher with a bunch of questions...old habits are hard to break, I guess.
Seriously, this is an excellent tutorial, at least for someone like me with no design experience, as I can actually follow your thought process and see what is going on...printing it out as you go is probably something that will help me see what is going on.
If I haven't scared you off with these questions, I look forward to the next installment!!
Cheers!
Jim
@ Leif - I saw the first part of your tutorial on repainting and know this is another class I really want to attend. I hope you don't mind with the crazy week I had last week I had to cut class for the last few days and haven't been able to do my homework. I can tell you, however, based on the parts I
did read that, as is usual with your threads and posts, the instructions are very well written and wonderfully illustrated. I hope to re-join the class sometime this week, if I may.
