Bob, I am in the process of building a road on my layout, and have already gone thru the work of determining proper widths. I determined 1-1/2" per lane. I have laid in a base 5" wide, 3' for the lanes, 1/2" each side for shoulders, remainder for sidewalk, one side only. Actual road construction can be approached many ways. The only road I built previously was poured using Durhams rock hard water putty. I was very happy with it. My current project is using styrene. On top of the 5" base mentioned, I will glue 60 thousanths strip down the center of the road to provide a crown. I will use 20 thousanths material for the road (scribed for expansion joints, this is a concrete road). The sidewalk will be 60 thousanths, also scribed. One question: If you run a road under your tracks, don't you need a bridge of some kind?
Gary
