hi-speed low-speed needle adjustments
Discussion in 'RC General & Getting Started' started by spacin, Jul 15, 2004.
Thread Status:
  1. spacin
    spacin New Member
    ok i fixed the problem i was haveing , no fuel into carb , i got my new mach.15 engine to start ran for a few then i gave it some throttle and it stalled not to start again, i guess the needles are out of tune and i tryed to return it to the factory settings of .. hs 2 1/2 turns from closed
    ls 4 turns from closed
    but it still wont atart back up
    glow plug is fine
    any ideas?
  2. redheat
    redheat Member
    Are you saying that your low speed is 4 turns out ,if so thats way to rich. turn that needle in at least 2 turns in. Go flush on the bottom L/S. That top end could be leaned out also. Make sure fuel is flowing to carb., check filters.
  3. rockn82
    rockn82 Marx Brother
    Make sure you have no holes in the fuel lines either and also make sure your fuel tank cap is sealing tightly
  4. Bloobert28
    Bloobert28 Member
    i had the same problem make them flush it works great
Thread Status:
