hey a plan =) or 2
Discussion in 'Track Planning' started by Im pavariangoo!, Dec 10, 2005.
  1. Im pavariangoo!
    Im pavariangoo! New Member
    hey whats the best choice between these plans???
    any advise or alternative plans would be appreciated.
    its 10 by 2 feet long and n scale
    many thanks
    im pavariangoo:cool:
  2. Pitchwife
    Pitchwife Dreamer
    They look pretty much the same, except one has a ladder instead of a runaround on the one spur. The biggest problem I see is the 2' width. To run a continuous loop your turn radius would be 11" at best, pretty tight curves unless you are only running short engines and rolling stock. Also that puts your mainline right on the edge of the layout. Nets might be advisable. :D
    You can click on the Model Railroad Links in my signature. The "How To" page has several sites for layout planning. You might check them out.
