Help with turntable
Discussion in 'Everything else' started by Drakeo1, Dec 25, 2004.
  1. Drakeo1
    Drakeo1 New Member
    Hi i have an old Technics turntable and i was wondering if anyone knew how to replace the belt on it. mainly how to get the belt on the turntable. i just dont know how to get the turntabel open to put the belt on
  2. yaniv
    yaniv Active Member
    can u please pic it or gave me the models of the truntebls?
    i have also 2 technics 1200
  3. yaniv
    yaniv Active Member
    i just chck how i do in mine
    my technics are not with belt its electronics
    but i all so chck for u in my old sherweed truntebel
    u just theck the dish out carefully
    then u roling the belt around the base (in the insid of the dish)
    then u stretch the belt around the belt dirive engine
    last part
    put beck carefully the dish and be wach thet the belt not tack out from the engin and the bass of the dish
    put the slipmet on
    tack one of your fivorit records (mine is "u spind em around like a record" :) )
    press start
    put the hede on the vinyl
    some loud volum
    and have fun :)
    hope its help
    if not i will add some pic
  4. Drakeo1
    Drakeo1 New Member
    I sort of understand ill try that
    by the way i Have a Technics SL-BL3
  5. Drakeo1
    Drakeo1 New Member
    Hey yaniv how do you get the table off is there a screw or somthing i missed. is there a certain way i have to turn it?
  6. yaniv
    yaniv Active Member
    its culd to be
    in mine i not have
    just theck it up with litel power (not to mach)
    with the hands sticking the fingers in the jold in the tabel
    copel of minits i tray to got u some pic
  7. yaniv
    yaniv Active Member
    sorry my freand but i not found any good pic on your truntebl :(
  8. cardfan
    cardfan Member
    You shouldn't have to open the unit at all. You probably just remove the rubber mat and pull up on the turntable itself. On my unit the belt rides on the outside edge of the turntable and to a small post on the drive motor.
  9. Drakeo1
    Drakeo1 New Member
    hey cardfan ive tried that but it only goes so far up
  10. Jim Nunn
    Jim Nunn Member
    Does the platter move up and down and can you pull the platter up over a 1/8 of an inch? If you can then what may be keeping the platter from coming up is vacuum you are creating as you try to remove the platter. I have seen this on most of the better turntables that have a solid shaft supporting the platter. On turntables that do not have a solid shaft you will typically find a clip ring on the support tube that protrudes through the support tube in to a grove in the platter shaft that keeps you from removing the platter.
    Lastly give Technics a call and ask if they can email you a service manual I know for the Pro Audio gear they will send out service manuals at no charge.
    Jim Nunn
  11. Texman
    Texman Guest
    What's a "turntable" ? ;^)
  12. Square
    Square Member
    alot of tables also have a keeper key or ring on the top side of the table remove it and the whole table comes up
  13. cardfan
    cardfan Member
    It is one of those things you use for what my children (teen agers) call "those giant disks". Man, now I feel old...
  14. yaniv
    yaniv Active Member
    lol cardfan
    i am only 22 and i have 3 at home
    all my room is full of "giant discks"
    then not fill so old
    the qulity of anlog music is the best and the filing of music in your hends
  15. Texman
    Texman Guest
    Ya only got me by a couple o' years. I used to have a
    Technics turntable, but sold the whole system before
    my present move. Actually had some kid ask me "What's that"
    when pointing to it. That one sunk in hard!
    Have a good one
