Help with Mk7 Viper
Discussion in 'Science Fiction & Fantasy' started by bemma, May 8, 2007.
  1. bemma
    bemma New Member
    I can't seem to figure out how to complete this model. The instructions (3 .jpg files) aren't helping me figure our where the engines go. I think I forgot the intakes behind the cockpit but I just can't figure it out (the 2 pieces in the middle right).
    Any suggestions would be appreciated.
  2. Jaybats
    Jaybats Member
    those are supposed to wrap around the rear cockpit/rudder assembly area before you attach the cockpit assembly to the fuselage. then you attach the engine cowlings around them.
    if you've already glued the cockpit assembly to the fuselage, then just cut out the white areas of those pieces, and attach them around the rear area of the cockpit assembly with tape. anyway they will be hidden inside the engine cowling.
    you'll need to cut out the "wall" at the end of the smaller intake to accommodate the long half-cylinder behind the cockpit.
    the "wall" at the end of the larger intake is what you attach the uppermost engine exhaust to. the rudder's corner sticks out, use that to anchor the upper exhaust's ends
  3. bemma
    bemma New Member
    Thanks for the help.
  4. Shin_kazama
    Shin_kazama Member
    thats exactly i did. though no or little creases for the fuselage...
    BTW, jay, pards, can you darken out your blackbird?
    also check out the colonial stealthstar pics thread.
    wonder if you could do that?
