help, Sticky switch, may have dropped white glue in it
Discussion in 'N / Z Scale Model Trains' started by PennCentralFan, Jun 5, 2006.
  1. or it may just be a sticky switch, but I was glueing down track with elmer's at full strength and one the switched got a little too much glue. Now it sort of sticks and doesn't respond as fast.
    What should I do? Apply water? Use WD-40. I'm using atlas code 80 N-scale track on a cork roadbed on plywood.
  2. piston_8
    piston_8 New Member
    water, file or pick and suction wet vac.
