Help motor only run full speed w/ only 1 screw
Discussion in 'RC General & Getting Started' started by danny_holtermann, Jul 22, 2004.
Thread Status:
  1. I bought a brand new stinger motor for my stampede, I have a novake duster 2 sport esc, It will run full speed If I only have one screw holding the motor on, but when I put the other screw in it runs at half speed and drains the battery just as fast.
    CAn someone help w/ this
  2. redheat
    redheat Member
    Start over with install, screw motor in place then wire it up correctly.
  3. So you put the motor in first? can it be the other way around?
  4. redheat
    redheat Member
    Is this your first R/C. In most cases you put the motor in 2 screws, hard wire thewires from the ESC to the motor. Next hook up the battery, your set.
  5. my first hobby rc that is electric yes, what do you mea by "hardwire"
  6. monsterrcbuilder04
    hardwire i think is when you have direct connection from motor to esc without connector. mine has little plugs so it can be takin out easily. i dont see why it would be having this problem but i would bolt it in first as red said
  7. redheat
    redheat Member
    How to resize the Kartonowka issue 4/2000 bombed out building to !/35th?
    Right on ,or you could go with a Dean connection, there the best in my opinion.
Thread Status:
