Help look like pepakura has gone crazy
Discussion in 'How Do I...' started by CrimosnBronxs, Jun 19, 2010.
  1. CrimosnBronxs
    CrimosnBronxs Member
    Help look like pepakura has gone crazy on me
    I have unfloded a model of starscream g1 cybertron ship
    and it's has doubled it
    When you loook at the model you can see a gray model and the color under it
    I thought at first it was fliped till i unfolded it and found the 2nd model
    now it is doing it with a few other ones I have unfolded and i have no clue as to why I know the mesh in 3d max is only one part so how comes pepakura is turning it into two or is it something i am doing wrong
    I need help
  2. Tirick
    Tirick Member
    The model is greyed because the normals are flipped. It is possible that there is a duplicate model as well (the flipped one likely).
    I'm not familiar with 3ds max though, so I can't help you there.
  3. legion
    legion Member
    You have double the faces because 3dmax renders backfaces, which are counted as separate faces in Pepakura. I do think that there is an option to turn those off in Max though.
  4. CrimosnBronxs
    looked into it and still no joy
    Have turned off backfaces removed the textures and re exported the mesh still the same thing
    Not sure what i need to change
  5. nav
    nav Member
    I've also used blender and there is the same problem.
  6. papercraftcouple
    papercraftcouple New Member
    Did you try to remove the double vertices in blender ? by pressing Tab to go to edit mode the press W and choose select remove double vertices
