help!!! i have a #215 santa fe engine with a mind of its own.
Discussion in 'G / O / S Scale Model Trains' started by ozzy, Aug 9, 2006.
  1. ozzy
    ozzy Active Member
    my engine all of a sudden started to jump from fowerd to reverse and back . all on its own. what is wrong with it, and how do i fix it.
  2. Guilford Guy
    Guilford Guy New Member
    I think your engine may have dirty wheels, I'm guessing your other engiens run fine
    Anyways on Lionels when power is interrupted to the motor the locomotive will siwtch to neutral, if its interupted again it willls witch to reverse, interrupted again and it will siwtch to neutral, if its interrupted once more it will go to forward
    If you have dirty wheels and power is interrupted the engine will change directions
