halinsky f-14a tomcat
Discussion in 'Aircraft & Aviation' started by The Hermit, May 26, 2008.
  1. The Hermit
    The Hermit Member
    halinski f-14a tomcat
    can any on point me to a photo build of this halinski kit?
    im having a hard time with it in some areas
    any help is appriciated
  2. logicman
    logicman Greybeard
  3. exzealot
    exzealot Member
  4. Master-Bruce
    Master-Bruce Active Member
    That's a very nic detailed model there. I can't make out the dialogue( not tried to translate mind) but that thread looks quite in detail.
  5. shoki2000
    shoki2000 Active Member
  6. Lex
    Lex Dollmaker
  7. The Hermit
    The Hermit Member
    thanks so much guys this really helps lots
    once again you set me straight
    now if i can just comeplete the model ill be ahead sign1
  8. dansls1
    dansls1 Member
    You could also post some pic's up for us to review your progress and try and help with any difficulties :D
  9. The Hermit
    The Hermit Member
    grudgingly i will agree, but i tell you that this model is intimidating
    i have only just begun and have made several mistakes that required "surgery" to correct.
    it is only with the study of 3 seperate model builds that i have been able to continue in the build of the model
    but each time i succeed after a "disaster" i find my enjoyment of the build increases with the complexity i encounter, this one aint for the faint of heart ...lol..
    i really have to say i am impressed deeply buy the german and polish modelers out there they are truely in a class by them selves and much can be learned by studying the builds that they provide on the other model websites.....
    and to you i thank you deeply cause i wouldnt have been able to continue
    and i appriciate the time you take to post them.... danke!!
    ill post some pics in a bit
  10. The Hermit
    The Hermit Member
    ok here we go. my build will be a hybrid sequence of the 3 other builds i reviewed and the original instructions, no guarantees that i wil go in order just what makes sense to me
    first off i build the cockpit frame as suggested
    make sure to cut out all extra spots if you are going to build the advanced version, i constantly forget to do it and i pay for it.
    i have a small supernova in my room so i dont know why the damn camera is using the flash
  11. The Hermit
    The Hermit Member
    im constantly amazed how complex and extreamly well engineered this model is
    check out the nose cone
    it looks sooo spiffy and well fit
    wait for it
  12. The Hermit
    The Hermit Member
    it is a movable nose cone for displaying radar inside
    its prolly the hardest thing i have had to do in modeling
    its got wood glue super glue some spit and i think blood somewhere....
    it is amasing how it fits together in the previous photos so seemlessly
    i have to hand it to halinski they really do design models well
    i am going to attempt to make it closeable since i have not seen any one do that yet since i like how it fits so well closed but we will see
    maybe i just leave it open static ... who knows
    fyi if you go this route and build the open nosecone DO NOT USE the glue strip or you will be cutting it off after it is assembled like i had too!!
    i slowly stitched the cowl hinge into place with super glue
    yes it was very hard
    money shot
  13. Lex
    Lex Dollmaker
    I'm so going to build a Halinski kit...!
  14. The Hermit
    The Hermit Member
    i tried to get a better shot of the hinge cowl its actually cutt off the front nose and it tapers wide and top to none at bottom and is extreamly difficult to glue much less in the correct position
    i advise patience and then strike with super glue sign1
  15. The Hermit
    The Hermit Member
    im going to bed last photo
    i was thinking to start the skin on forward cockpit but i decide to finish radar first more photos later
  16. exzealot
    exzealot Member
    This is great! Halinski kits can be intimidating; that's for sure. My first paper model was the Halinski Tornado. However, the good news is that Halinski kits, in some respects, are the easiest to build from the standpoint of design accuracy, and easier-to-understand graphics. Screwing up is a GOOD thing - that's how I learn anyway. Hang in there! Keep going, don't stop, take your time and enjoy the build. We will enjoy your build as well. :thumb:
  17. The Hermit
    The Hermit Member
    my blackberry camera sucks at macro photos
    i only get about 4 hrs max to work on model after work
    even so working on the radar assembly eats time like a black hole
    all most competed it tonight but the radar antenna t's are tiny to cut and slow going
    picture below
  18. The Hermit
    The Hermit Member
    new camera arrived
    the new camera arrived today, thanks to those who helped.
    we chose the canon powershot a580
    it is producing excellent results
    here are some new photos of the model
    and they look much better
    muhahhaa looking at the above photo for comparison
    im impressed
  19. The Hermit
    The Hermit Member
    im starting to get into the harder parts of the model
    but i trudge on...
    they landing bay was more difficult than i had thought
    i abandonded white glue and used only super glue sparingly
    it achieved good results
    im still loving the camera
    it takes beautiful shots
  20. The Hermit
    The Hermit Member
    and before i forget the nose gear ala solo
