Grumman F-14 Tomcat
Discussion in 'Aircraft & Aviation' started by JT Fox, Oct 1, 2008.
  1. JT Fox
    JT Fox Member
    This model was designed by Triop.
    Not that many parts and a fairly simple build which suits me.
    The only problem I had was the fuselage which is made from 4 parts. Top, bottom and 2 x sides. When gluing this together I failed in my efforts to keep it square. As a result there is a slight up angle to the wings,(which I modeled in the forward position).
    I was aware before the build that the the result would be back heavy but didn't weight the front as I liked the idea of a take off/land look.
    Cheers JTF
  2. JT Fox
    JT Fox Member
    I'm having a go at re-colouring Triops F-14 in Iranian Air Force desert camo.
    Progress so far.
    Cheers JTF
