Griswold Concrete Block
Discussion in 'Scratchin' & Bashin'' started by Matthyro, Feb 25, 2004.
  1. Russ Bellinis
    Russ Bellinis Active Member
    I've seen some files with pretty aggressive teeth. I think I've seen some with big enough grooves for O scale siding.
  2. Matthyro
    Matthyro Will always be re-membered
    Here is a close up of the conveyor Dash.
      File size:
      50.1 KB
  3. Fred_M
    Fred_M Guest
    Thanks Robin, that looks nice as always.:thumb: FRED
  4. ezdays
    ezdays Out AZ way
    Fantastic as always Robin. A question: How did you get that texture on the siding? From the pictures it looks like you have both board and batten and wood shingles.
  5. Matthyro
    The walls are made with 1/16th strips of cardboard glued to the base Don. Some vertical some horizontal
  6. ezdays
    ezdays Out AZ way
    OK, let me see if I got this. You first made a wall out of cardboard from cerial boxes, then glued on more strips of it to simulate the individual wood boards..:cool:
  7. Matthyro
    Here the factory is installed on the corner Ntrak module.
      File size:
      35.4 KB
  8. Matthyro
    From the other side.
      File size:
      30.9 KB
  9. Fred_M
    Fred_M Guest
    Looks fantastic. Just the right amount of weathering. FRED
  10. Will_annand
    Will_annand Active Member
    I heard that they watch the golf channel at our local hospital, it is very therapeutic....... it cures insomnia.
  11. RailRon
    RailRon Active Member
    Robin, your Griswold module is an absolute top notch masterpiece! :thumb: :thumb: :thumb:
    It shows the contrast between the 'upper class' and the 'lowly' side of the RR tracks in a very fascinating way.
    Great modeling, and thanks for sharing it with us!
  12. Clerk
    Clerk Active Member
    WOW Robin. I tried cutting 1/16 " cardboard just to see if I could do it. I ended up with junk.
  13. davidstrains
    davidstrains Active Member
    Try a thinner card stock like an index card or manila file folder. It may curl a little but it comes out very useable. I also reload the xacto blade frequently.
  14. spitfire
    spitfire Active Member
    Can't think how I missed this thread. Another great industry from the master scratcher!!!!! Very nice as always Robin!!!
    :thumb: Val
