grinding motor off of full throttle starts
Discussion in 'RC General & Getting Started' started by bandit1, Aug 16, 2003.
Thread Status:
  1. bandit1
    bandit1 Member
    i just cleaned my motor and the first run after doing that it ran fine. now when i take it out when i go full throttle or close to full throttle my motor makes a grinding sound. as it picks up speed it goes away. also my ESC is running warmer than usual. the motor is fairly new, a couple weeks. any1 know whats going on?and possibly how to fix it. Thanks...
  2. bandit1
    bandit1 Member
    sorry guys...spoke too soon...took it out again and figured out that my slipper clutch was too tight, i loosend it a little bit and now its back to normal. but thanks anyway for any1 who would have responed.
  3. bandit1
    bandit1 Member
    now its back again....any suggestions its not the spring tension on the slipper clutch...
  4. casey
    casey Member
    sounds like your differential needs to be rebuilt mine needs to be rebuilt too i havent had time mine waz doin the same thing
  5. bandit1
    bandit1 Member
    how would i go about doing that. i have taken apart my tranny case to see if any gears were stripped but thats not looking for any prblems on the diff. When u say re-build it how would i do that. Thanks for the tip.
  6. casey
    casey Member
    change the balls to carbide balls and lube every thing up what kid of truck do you have??
  7. bandit1
    bandit1 Member
    thanks.i have an Evader ST.
  8. bandit1
    bandit1 Member
  9. MrPhoney
    MrPhoney New Member
    Have you check the gear mesh? If it is too loose it can make that grinding noise. Look at the spur gear to see if it is chewed up.
  10. bandit1
    bandit1 Member
    ya i checked the gear mesh on the spur to pinion with a piece of paper and it was fine. Im really leaning on the fact that my diff. is screwed up. i think im gonna end up replacing it. its not too expensive anyway.
  11. timrock
    timrock Active Member
    it also could be, and more like is,the plastic ideler gear
  12. timrock
    idler gear
Thread Status:
