got hose?????
Discussion in 'Tips & Tricks' started by railroader9731, Oct 18, 2005.
  1. i know i do rather cheap again first find old black speaker wire or a old power addapter. cut the wire to the length you desire and carfully pull the wire it self out of the caseing ( cut just for a pair of needle nose plires to get a grip) good luck:p
  2. Dave Harris
    Dave Harris Member
    Another source for scale hose is what they call
    rubber Legs at a fly tying shop. They come in strips that tear apart & are used for Legs on creepy crawleee looking flies.
  3. Painted solder makes great hoses, as it can lay down and drop quite realistically.
  4. doctorwayne
    doctorwayne Active Member
    Spaghetti or spaghettini also works well: cook it a bit beyond al dente and it will be nice and pliable, making it easy to coil or drape where required. After you've shaped it the way you want (often, it's best to place it where it'll ultimately be used), let it dry until it's hard, then paint an appropriate colour.
  5. Mountain Man
    Mountain Man Active Member
    Thanks - those are useful tips!
  6. Sawdust
    Sawdust Member
    Home made hoses
    I also cut the outside sheathing from phone wires. The inside wires are great for hoses & you also have several color choices as well. Jim
  7. Dave Harris
    Dave Harris Member
    HEY , I found some of the Rubber legs at Cabbellos Sports Shop that are not "sheeted" here is a pic. I put a toothpic next to them to show their size. I think they were about 4 dollars.
