gluing wood flat cars together
Drew1125
2,975
Hi Shawn,
For gluing wood to wood, I use either Elmers white glue, or the yellow carpenters glue…
For gluing wood to plastic, or resin parts, I use CA adhesive…There are several different types of this glue…I use a type called Insta-Cure, which is thicker than the regular “super glue” type of CA…
Drew1125
2,975
Matthyro said:
Like Drew, I have used the yellow carpenters glue. I imagine the white glue would work fine too.
For bigger projects, using heavy stock, I think the yellow glue is better...But for lighter stock, the white glue is just as good.
