I'm working on a building flat made of cast plaster wall sections. Behind the plaster panels will be a wood frame ( 1x3 frame and masonite). My question is should I seal the back of each panel before I glue them to the wood or not ? I have sealed the wood to prevent it from warping. I had thought to white glue each panel together end to end and use an adhesive like no more nails to glue them to the masonite backing. I want the adhesive to also act as a levelling agent. So should I seal the plaster ?
kj
kj
