Glue, Which one
Discussion in 'HO Scale Model Trains' started by scoobyandy, Oct 24, 2005.
  1. scoobyandy
    scoobyandy New Member
    I am about to start on my layout and wanted to know what is the best kind of glue to use to fix down scatter etc.
    I have a bottle of wood glue that i was going to use to start with but wanted to know what kind is best and if it should be watered down.
    Thanks for the help
  2. Russ Bellinis
    Russ Bellinis Active Member
    By "scatter" I presume you mean scenery materials, most people I know use a 50% water/Elmer's white glue mix.
  3. green_elite_cab
    don't roget soem dish washing fluid to help get the glue in all the cracks!
  4. jim currie
    jim currie Active Member
    for putting down ground cover i use spray adhesive if your meaning ballest then a 50/50 mix of water and white glue is used.also a friend uses latex paint in a earth tone to put his ground cover down.
  5. ausien
    ausien Active Member
    I spray the aerea with a solution of 50/50 white wood glue and water, spead the cover slowly and then spay again from a hight of about 6-8" with the adition of the dish soap untill wet, but not soaked, this seams to stick almost anything that I use on my layout.
    I hope this info helps you... have a good one.. steve.
