Glow Plugs
Discussion in 'RC Offroad Forum' started by Justin_E, Jul 24, 2004.
Thread Status:
  1. Justin_E
    Justin_E Member
    Whats the best glow plug I can get for my RC10GT? Is there one that makes my engine run cooler?
  2. redheat
    redheat Member
    Try a MC 59,Your running the AE .15 right? To make your engine run cooler try the following , trinity monster blend 20% this fuel has more oils for lubrication than any of the others, brand new MC59, clean air filter, make sure that you dont have any drag on your drive train for example make sure that your tranny is in good working order,wheels are snug but not overly tight causes strain on the drive train. And make sure that the motor is set up right H/S and L/S needles . To check the tranny turn both wheels at the same time in the same direction they should move freely ,if you feel grinding as you turn the wheels chances are that you need to rebuild.
  3. Justin_E
    Justin_E Member
    Ya Im runnning the .15 Im actually running 10% O'Donnel, its too hot here to run 20 unless youre racing hardcore.
  4. redheat
    redheat Member
    NO,NO , my friend 20% is the standard, I'm running in 100plus deg. Just try what I talked about in the post above.
Thread Status:
