I'm not sure what you are actually looking for.
Most of the model railroading magazines used (some still do, but not Model Railroader) to publish scale plans of locomotives, cars, and buildings. Some books on prototypes also publish these scale plans. Very few plans for trains would be drawn in N scale because of the loss of detail and room for annotating dimensions.
Plans drawn in other scales are easily converted to N. You can use precentages in copiers to reduce the plan to N scale. Or you can simply measure a dimension on a plan using a scale ruler for the scale the plan is drawn in. Note the prototype dimension, then measure your material with the N scale line on the same scale ruler. Almost all scale rulers have mulitple scales on them, including N and HO.
hope this helps
