gears
Discussion in 'RC Offroad Forum' started by terrell1902, Jul 25, 2004.
Thread Status:
  1. terrell1902
    terrell1902 New Member
    I have an Associated RC10 GT rtr plus. I want to know how long do a spur gear last. this is my 3rd gear. can anyone help me, thanks
  2. Justin_E
    Justin_E Member
    They should last pretty long. Put the pinion closer to the spur next time. But not too close. Put a peice of paper between the spur and pinion and push them together, that will be close enough.
  3. monsterrcbuilder04
    i put mine close as i can spin it freely with my hand.if you cant spin the gears with your hand it is too tight
  4. redheat
    redheat Member
    There you go .Thats good info. guys thats how I do it and yes they should last a long time, before replacing with new one make sure that your motor mount is tight and your motor is secured tightly to the mount. Two major causes of stripped spur gears are , gear mesh to tight or loose, and motor slipping on the mount or chassis
Thread Status:
