Gearing
Discussion in 'RC Offroad Forum' started by Vinh Nguyen, Jul 29, 2005.
Thread Status:
  1. Vinh Nguyen
    Vinh Nguyen New Member
    I just got the wasp .28 engine for my prp katana buggy. I want to know what gearing should I put it???
  2. RC King
    RC King Member
    what gears do you have?
  3. dj6666969
    dj6666969 Active Member
    Do you wana go fast or have alot of torgue?
  4. Vinh Nguyen
    My gearing right now is 14/46
    and can u tell me both for torque and for speed??? thank u
  5. dj6666969
    say useing a 17 tooth pinon and a 44 or so spur gear this will give it more speed. When you use a larger pinon and a small spur gear your looking at higher speeds. Now if you were to go down to like a 12 or so pinon and a 50 tooth spur this will creat more torgue and even moveing just a few teeth will make a difference.
  6. RC King
    RC King Member
    changing the pinion 1 tooth makes a much bigger difference than the spur gear 1 or even 3 teeth.you want more torque?go with a smaller pinion/clutch bell gear.experiment with that.if you find you have alot of torque but not much top end speed then raise the # of teeth on the pinion /clutch bell gear.
    when you have a good running engine and a few different gears to experiment with,it can be very interesting and fun.
Thread Status:
