Gas
Discussion in 'RC Aircraft & Watercraft' started by Patrick Bessette, Sep 7, 2004.
Thread Status:
  1. Patrick Bessette
    Patrick Bessette New Member
    What will happen if I use 89 octane fuel with my 30 cc Homelite Boat engine?? Will it burn up my piston??? If anyone can help me , I'd appreciate it. Thanks
  2. Ron Olson
    Ron Olson Member
    The Gas engines run better on low octane gas.
  3. boatman
    boatman New Member
    your homelite is a 2cycle motor you must have oil in the gas
    i believe it has a 32 to 1 oil mix
    strait gas will burn it up
    it needs the oil & gas to lube the piston & rod bearings or it will lock up while running
    the oil in the gas is the only lubercanit for the whole motor
    dont run strait gas
    any octance will work good
    hope this helps you out & dont forget the oil
Thread Status:
