Gandy Dance Dissection
Discussion in 'FAQs' started by Doc Holliday, Mar 2, 2005.
  1. Doc Holliday
    Doc Holliday Member
    Gandy Dancer Dissection
    I'm about to take apart a perfectly good Bachman gandy dancer. I want to strip away all the non-essential parts, leaving only the motorized chasis and wheels. Has anybody out there done it and can tell me where to start? :confused:
  2. N Gauger
    N Gauger 1:20.3 Train Addict
    YOu mean the yellow one - the powered one with the trailer??
  3. Doc Holliday
    Doc Holliday Member
    Here is a pic of what I'm talking about.
      File size:
      28.2 KB
  4. N Gauger
    ah - Out of my league :( I thought you meant the G one :( Good Luck anyway! :)
  5. shaygetz
    shaygetz Active Member
    I don't envy you, I did one last year about this time. That side screw is the key, everything else is held together by the two halves of the frame. Rather clever---just make sure you do it over a table with a white sheet over it. There's a spring or two I recall by the motor brushes set to go suborbital if you're not careful. ;) :thumb: :rolleyes:
  6. jon-monon
    jon-monon Active Member
    I've done it, plus cut off the tool boxes with a dremel. Makes a small, but poopy power truck. 2wd. It can pull one flat car on the level LOL
    If you can handle a slightly larger truck, a bach 44 tonner (old style) or 70 tonner would offer two that run better, and have removable side frames. The gandy will run fine if it's for a speeder or such and won't need to pull much.
  7. MasonJar
    NWSL makes powered trucks for HO scale... Maybe a cheaper solution than stripping that Bachmann gandy dancer...?
  8. jetrock
    jetrock Member
    The NWSL "PDT" is a lot bigger than that Gandy Dancer--although the "Flea", a "build your own power truck" device, is pretty tiny. The old 44 tonner power trucks are more compact than a PDT, although taller.
  9. Doc Holliday
    Doc Holliday Member
    Thanks for the suggestions. Jon, that's a pretty cool "critter"!
    I've already got the gandy dancer (used from ebay) and want as small a platform as possible. I don't plan on pulling anything so the limited power shouldn't be a problem. I guess I've just got to take a deep breath and start cutting.
  10. jon-monon
    Thanks, Doc :D You'll do fine, fire up that dremel!
    Jet, you can flip the motor on its side and reduce the height on a 44 tonner truck. Steeple cab trick :)
    Andrew, the NGSLs are presumably a much higher quality, and definately a higher price. Trainworld has gandys for $15. 44 tonners were $30, but theve only got the new style now :( They both use the same weak, unreliable motor.
  11. LIRR
    LIRR Member
    That gandy dancer allways looked like two guys playing a piano to me. I used to run mine off unfinished sections of elevated track when i was little, never broke.
  12. jon-monon
    hehehe I like to run them full blast. I've got one of the old metal manned ones I can't get myself to cut up :D
